Does Labview have function Mod() ?
Hello, everyone,
I am trying to parse an array only for all its odd/even number elements.
I am thinking of use Mod function upon 'iteration' but labview seems have
nothing there.
Does anyone know something about that?
Thanks in advance,
-Kunsheng
Message 1 of 17
(35,272 Views)
Accepted by Kunsheng Chen
It's the Quotient & Remainder function on the numeric palette.
Message 2 of 17
(35,266 Views)
If you want to get the modulus of a number then use the quotient & remainder function in the numeric panel (block diagram).  Use the top input labelled X-Y8Floor(X/Y).  This is the mod().
Message 3 of 17
(35,264 Views)
The "Sign" function in the Numeric palette returns a "-1" for a negative number and a "1" for a positive number. If you multiply your non-zero number by the outcome of this function, your number is returned positive and this becomes essentially a Mod[number] function.
Message 4 of 17
(32,914 Views)
No, that is ABS(number).  MOD needs 2 inputs: the number and what the base is.  For instance MOD(3,2) is 1.  The easiest way to think of MOD is the remainder when you divide two numbers.
Message 5 of 17
(32,904 Views)
I found my way to this page because I was looking for a modulus function in the mathematical sense, i.e. In mathematics, the absolute value (or modulus) | a | of a real number is the numerical value of a without regard to its sign.
Message 6 of 17
(32,897 Views)
Interesting.  I never heard absolute value be called modulus before.  I just hit wikipedia to check.  In every sense I've heard of modulus (including a few math and cryptography classes), it is remainder (http://en.wikipedia.org/wiki/Modular_arithmetic).
Message 7 of 17
(32,893 Views)
I don't doubt your knowledge in this area, I was just defending my corner.
http://en.wikipedia.org/wiki/Absolute_value
Message 8 of 17
(32,888 Views)
@Kunsheng Chen wrote:
Hello, everyone,
Save yourself the looping, why not just use decimate 1 D array?
Edit: Misread, you want the even/odd elements, not even odd indices.
Message 9 of 17
(32,884 Views)
That's because technically it's modulo, not modulus. Pesky mathematicians.
Message 10 of 17
(32,878 Views)
