01-17-2017 06:27 AM
I have a labview project that needs a gpib address. Basically I am using another equipment that is connected through GPIB to my computer. The equipment can be programmed to send data and commands to another GPIB address. I need to give my Labview project a GPIB address to receive the data and commands. The GPIB address cannot be 0 or any GPIB address that is allocated to the equipment. Is there any way to set a gpib address for the labview project.
Thanks for your help.
01-17-2017 07:01 AM
Hi basetgh,
Simple answer: use a string control to set the GPIB address… 😄
(You surely need to scan the allowed GPIB address range for devices to be sure you don't accept a GPIB address already in use!)
Why do you need to use LabVIEW here? Can't you save such settings within your device(s)?
01-17-2017 07:40 AM
The equipment is a keysight measurement unit that uses easyexpert software. It only accepts GPIB address to control.
Easyexpert software does not have enough programming ability to control other equipment (such as light sources). It can send data through gpib saying if the test has been performed or not. I use Labview to control my other equipment.
01-17-2017 07:44 AM
I think the OP is trying to be a GPIB Slave, which is really weird to me. So the first thing to do is make sure your GPIB controller can be configured to be a slave. If so, you should find the address with that setting.
01-17-2017 09:15 AM - edited 01-17-2017 09:16 AM
Sounds like you need to dump that Easyexpert program and write some LabVIEW to comunicate directly with your instrument and make it do what you want it to do.
01-17-2017 09:21 AM
Is it possible to use extra computer? If I could communicate with two computers through GPIB, it would be possible to set the EasyExpert as one GPIB address and set the other computer with its uniqe GPIB address.
I checked the link below and could not understand the second part. Is it possible to connect two computers with their unique GPIB addresses?
http://digital.ni.com/public.nsf/allkb/9CC0939663F1C5DE862565D70082E89E?OpenDocument
01-17-2017 09:22 AM - edited 01-17-2017 09:24 AM
Hi basetgh,
"computers" usually are GPIB masters, while you seem to need a GPIB slave.
Do what others (like crossrulz) have suggested before!
When your measurements aren't that complicated to program I also advice to dump that EasyExpert tool and create your own LabVIEW tool to do those measurements…
01-17-2017 09:32 AM
Basically I have another computer and I would be happy to use another one as slave to have labview on it, then the first computer can be used to run EasyExpert.
I have checked some links such as the one below that it is possible to do this configuration. however I do not understand the second part. Could you please explain how can I make one computer as slave and the other one as controller that gives me two different GPIB addresses!
Thanks a lot,
01-17-2017 09:54 AM
