05-10-2021 01:14 PM
I have a small application where I need to take measurements from a NI-6009 DAQ and control a motor using Modbus RTU. I realize the download and installation of the Modbus library would be required. Does the Labview Base Package support the Modbus library?
Thank you,
05-10-2021 01:22 PM
Yes
05-10-2021 01:25 PM
It should. LabVIEW Base supports "network communications" per this page, which is all that it should need.
There's 3 or 4 different MODBUS libraries out there, and some of them are closed (password protected) so it's hard to be totally sure they will work but the open ones definitely should.
05-10-2021 01:30 PM
