Display numeric as standardized scientific notation
This must have been discussed before but I cannot find it.
In LabVIEW, scientific notation is displayed in the form "1.234E+5", but the standard for scientific notation is 1.234 x 105.   I would like both numeric indicators and graph scales be able to display like that. Is there a reasonable way to get that? I’m guessing no since there is a superscripted character in there.
But can NXG do it?
At least it would be nice to get graph scales in this format (whatever it is called): 105.
Bonus points to anyone finding a way of formatting SI units the standardized way, with a space between the value and the unit, like "2.4 GHz", standard SI style convention. And no, "%#p Hz" is incorrect.
Certified LabVIEW Architect
Message 1 of 13
(7,281 Views)
Hi thols,
Yes. Like here
I guess NI follows the "industry standards" with same (or very similar) format codes as in any other programming language…
(You can always create your own formatting/conversion routines to create 2D pictures containing the requested "1.2345×10³"…)
Is it really "standard" to place the char "x" (ASCII-120) in between the numbers? 😄
Message 2 of 13
(7,270 Views)
But can NXG do it?
It must be some kind of standard, because if you paste "1.234E+5" (sans quotation marks) into any spreadsheet application, you get the number.  I think this must be a standard for SI units in a computer-ready format because you'll find almost every instrument will output numbers in this fashion.  I've never seen an instrument return numbers in what I would call "human-formatted" SI units.  Takes too many extra characters.  1.234E+5 or 1.234 x 10^5.  Too much wasted space - half again as much space - taken up conveying exactly the same information.
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(7,228 Views)
If forgot to mention that your request is entirely reasonable, though.  And as for part 2 of your post, that really annoys me as well.  There should be a space, and the fact that there isn't makes that format useless to me.  (Probably my tendencies towards OCD is in play here.)
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(7,221 Views)
I just don't have the space and I am content (%#pHz).  There was some discussion about this in the Rube-Goldberg thread.
Message 5 of 13
(7,209 Views)
It wouldn't surprise me if that discussion was the trigger for this thread!
GCentralI'm attending the GLA Summit!
Message 6 of 13
(7,190 Views)
@GerdW wrote:
Hi thols,
Yes. Like here
Speaking as a Mathematician, I'd say "No, that should be a Times sign".  3 × 10 is different from 3 x 10.  I typed the Times sign by using the numeric keypad and Alt-0215.
Bob "Picky" Schor
Message 7 of 13
(7,187 Views)
But can NXG do it?
Also, can you get the exponent in prefix sizes? I don't have LV on this computer so can't check right now. On a calculator you can often press ENG to write it in 'engineering' units, so 1.234E5 becomes 123.4E3 (the exponent is always a factor of 3).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 13
(7,176 Views)
Hi Yamaeda,
From the LabVIEW help on "format strings":
Add ^ to change to engineering notation where the exponent is always a multiple of three.
Message 9 of 13
(7,152 Views)
I thought this sounded familiar!
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(7,145 Views)
