10-14-2019 01:59 PM
If you set UseUnicode=True in your labview.ini file, you can use the Unicode superscript characters. Unfortunately on my machine, the Unicode superscript chars for 1,2,3 don't look the same as those for 0, 4-9.
10-15-2019 02:00 AM
What I lack the most is to make nice graph scales really.
And then I thought, hmm, why can’t I format it like that for numbers too, anywhere.
And then I threw in the SI unit formatting annoyance I mentioned in the rube-goldberg thread.
I want this:
Or even:
(from https://journals.aps.org/authors/axis-labels-and-scales-on-graphs-h18)
When displaying numbers to a user, it should be possible to display it by math-standards, rather than programming-language or pocket-calculator standards. Maybe I should hope for NXG to handle this, or maybe explore some external component when it comes to graphs. But more creative solutions are welcome.
The picture-idea from GerdW might work, if either the number could be processed by something that creates the picture or to make pre-made pictures of the “× 10n” and then merge with the number. The drawback is that it cannot be used as a number, e.g. selected and copied or changed by the user.
Bob/GerdW: I accidentally put an X instead of the “times”-sign there. Thanks for noting!
paul_cardinale: Oh yes, Unicode. I haven't explored that much. When I read that it is not official and unsupported I chose to stay away from it.
10-15-2019 02:34 AM - edited 10-15-2019 02:35 AM
Hi thols,
I can recommend Origin to create nice looking graphs.
When I was using it (10 years ago) there was even the possibility to remotely control Origin…
