Showing results forĀ
Search instead forĀ
Did you mean:Ā
Display array data in a Listbox
Hi
I am trying to display array data in a single column listbox. The data value in array is String format. How can I change Listbox type to string?
Thank you
Message 1 of 13
(14,060 Views)
You don't have to change anything. The ItemNames property is a string array and this is what you write to populate the listbox. Just write click on the listbox and select Create>Property Node. Right click on the property node select Properties>Item Names. Right click on it again and select Change to Write.
Message Edited by Dennis Knutson on 04-16-2007 09:51 AM
Message 2 of 13
(14,049 Views)
I think that what you want it's what I've made on the example
See it..
Software developer
www.mcm-electronics.com
PORTUGAL
Message 3 of 13
(14,046 Views)
It works. Thank you.
Message 4 of 13
(14,034 Views)
Is it possible to display data from two arrays in one multicolumn listbox?
Message 5 of 13
(14,034 Views)
Yes, just concatenate the two arrays using a "built array" function (wire it up, then right-click on the "built array" and select concatenate mode).
Message 6 of 13
(14,027 Views)
I have two of one dimensional arrays . I would like to display data from two arrays in 2 columns listbox. When I try your suggestion, it works with one single colum listbox. Not multicolumn listbox.
Thank you.
Message 7 of 13
(14,023 Views)
Sorry, simply don't concatenate the arrays in the "built array" node and you'll get a 2D array. The rest stays the same. šŸ™‚
Message 8 of 13
(14,015 Views)
Me again. It does not show in separate columns in the listbox. I would like to know how the data in each array can display in separate column.
For example,
array 1 = {1,2,3,4}
array 2={1.2,1.3,1.4}
In multicolumn listbox, array 1 should be display in first column and array 2 in second column.
Thank you for your promptly help.
Message 9 of 13
(14,006 Views)
Well, just transpose the 2D array then to swap rows and columns. šŸ™‚
Message Edited by altenbach on 04-16-2007 01:29 PM
Message 10 of 13
(13,998 Views)
