Disabling entry into empty ARRAY element ?
Yeah, but look at the picture I posted above.  Yes, I can prevent them from adding things, but it's ugly to have it there. That's really what I'm trying to get rid of.
Giving them a place to type and then saying "no, no, you can't do that" is bad UI.
I'm working on Ben's idea with a customized array control, and struggling with the weird interface for customizing (error bells that tell me nothing, handles for resizing things that don't really resize things, etc.).
I got it to work with a slider, but oddly enough, it won't work with a scrollbar.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 18
(1,501 Views)
When replacing parts be very careful to get the data type correct or it will just beep at you. So if the scrol bar is U32 make sure what you are using to do the replacement has the same data type.
Ben
Message 12 of 18
(1,499 Views)
OK, thanks, Ben.
I've made it work, though it's not like I would like it.
Can't seem to make the scrollbar work.  It just dings when I replace the slider with a scrollbar.  I did set the scrollbar to U32, but no go.
Anyway, thanks for your thoughts.
Steve Bird
Culverson.com
LinkedIn
Message 13 of 18
(1,496 Views)
Please support >>>> this idea <<<<! it is really needed!!!
Why does it only have 24 votes????
For more details, also have a look at my comment and the link in it.
Message 14 of 18
(1,496 Views)
Well, I added my support, so I'm sure NI will get right on that.
Steve Bird
Culverson.com
LinkedIn
Message 15 of 18
(1,491 Views)
I should explain that I set the slider size for 15 rows, but for testing, I set the array to be six rows high.  Anyway, it works, because when the scrollbar is at the bottom, the last row shown is #8 out of 8.
The code is simple:
Array.NUMROWS = min (array.length, max screenspace)
Array.INDEX VISIBLE = array.length > max screenspace
Slider.Scale.MaxValue = min(array.length - max screenspace,1)
(use the minimum 1 to keep out of a min=0, max=0 situation)
Steve Bird
Culverson.com
LinkedIn
Message 16 of 18
(1,489 Views)
I am assuming this was a reply to my post. If you used that approach you would not have the slider. In addition, if the user began typing something in it is true it would be there while they entered the data. However, the data would not be included in the array when they hit the add button. In addition, you could clear the erroneous row they tried to enter. I have used the transparent control and it works fairly well. I was only offering an alternative method.
In the past I have implemented my own scroll bar for the array and managed its range based on the size of the array. Here is the code I played around with as I was developing it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 17 of 18
(1,476 Views)
--- Understood.
Yes, but I want them to be able to edit anywhere on the display - any of the 15 rows. It's cumbersome to have to pick a row from the display, and have another control show the data where they can edit it, then they click ADD or DONE or something.
Steve Bird
Culverson.com
LinkedIn
Message 18 of 18
(1,464 Views)
