Digital waveform editor
Does anybody know how it possible to send a pattern saved in hws format  from the DigitalWaveform Editor, to the NI6534?
any help is welcome because  I couldn't fin anywhere how it is feasable.
Message 1 of 8
(4,089 Views)
Dear,
In attachement an example of reading a hws file and generating.
You can also find this example when you go to help in labview --> find examples and then enter
hws as a search query.
I hope this helps you!
Kind Regards,
Joris Donders
EMEIA GTM Lead for Semiconductor
www.ni.com/semiconductor
Message 2 of 8
(4,070 Views)
Dear,
I'm sorry to say but i made a mistake, the example i gave you previously will not work together with the hardware
you are using, i didn't tought of that before.
There is no standard example to show you what you need to do. But i will make an example that shows you the
priniciple asap. If for some reasone the example i gave you works, let me know, but i don't think it will.
Joris
Kind Regards,
Joris Donders
Message 3 of 8
(4,042 Views)
I found this post on the forum, where someone wants to do more or less the same thing as you.
http://forums.ni.com/ni/board/message?board.id=250&message.id=24909&requireLogin=False
All the information you need is included in that post. Take a look at it and let me know if you have
got sufficient information to solve your problem. If not, I can always help you some more.
Kind Regards,
Joris Donders
Message 4 of 8
(4,026 Views)
Thank you SirJoris,
I will have a look and let you know asap.
Benio
Message 5 of 8
(4,011 Views)
SirJoris,
I have try to use the the NHSDIO function in combination with the DAQmx one unfortumately the function are not matching(see the picture).
any idea what I did wrong?
Message 6 of 8
(3,987 Views)
Hi
It seems that you have just taken the wrong vi to open the hws file, you should use the NiHWS retrieve waveform vi.
Look at both pictures in attachment, they will explain what you did and how it should be done.
You should find the retrieve digital waveform vi, when you search in the function palette for retrieve.
If you can't find it with search, then the ni hsdio driver is not installed.
Go to http://joule.ni.com/nidu/cds/view/p/id/872/lang/en and download it there. Install and then you should find the correct
vi in your function palette.
Kind Regards,
Joris Donders
Message 7 of 8
(3,962 Views)
SIrJoris,
I have now the following error si attacched,
Message 8 of 8
(3,949 Views)
