Digital Filter
Yes I am trying to do that, and the output should be in form of graph clusters which also gives error, the ones in the image are just clusters into which I need to bring graphs. I am using waveform graph vi which gives error when a bundle of 3 inputs is connected to it. Do you know how can I remove this error. I can send the  .VI file if you want.
Message 11 of 12
(655 Views)
Well that will always give you an error because you're trying to connect different date types.  Try this instead: create a cluster which contains three elements.  The first is a double which represents the starting frequency of the spectrum, the second is a double which represents the frequency step and the third is an array of doubles for the spectrum data.  Wiring a cluster of this type to a waveform graph will work so use this to collect your data for plotting.  You also need to get rid of the empty case in the case structure.
Message 12 of 12
(650 Views)
