Different behaviour when run in development environment or as built executable.
This question was first posted as a followup (here) - but it clearly is a separate issue that warrants a new question. You can see some background info there, however.
I've created a simple VI which demonstrates the issue. It's attached, as is a built version of the application.
This VI uses the Windows API to create a live feed from a USB webcam, it then allows the user to save a still from the camera to a chosen location. It was created as a workaround for a project that can't afford the runtime license for NI's IMAQ drivers, let alone a development license for them.
The image save is achieved by copying the webcam feed at a given point in time, and then fetching the copy from the clipboard in order to get a savable image.
This works very well when the VI is run from within LabVIEW's development environment, however it consistently fails when run as a built executable.
It appears to be the saving that is failing overall. Debug indicators suggest that something about the interaction between copy & Clipboard.Get Image is wrong. I don't think it's a race condition however, as I've been quite careful with the wiring with respect to that, I've also looked into it a bit already - which I'll explain a bit below.
Any help anyone can offer would be greatly appreciated!
**Further info from my debugging efforts below, not required reading!**
I'll do my best to describe what I've found so far by watching debug indicators, but it'll be easiest to see by just running the VI:
If the clipboard is empty:
- No image is saved
- Indicators show no image is fetched from the clipboard
- Opening paint and pasting produces the image that should have been saved
-> I'd think "Oh, clearly the copy is happening after the paste" however, if I then tried again I'd expect:
-The previous image to be saved
-Indicators showing the previous image
However, the behaviour is exactly the same as the first attempt.
If the clipboard has something in it already (a string or something - I think specifically if it was copied from within the application...):
- An image of the previously copied item is saved
- Indicators show an image of the previously copied item
- Pasting into paint afterwards produces the image that should have been saved.
->As before, instead of the expected behaviour if this were due to a race condition, instead when trying again I get:
- An image of the previously copied item saved again.
- Indicators still showing an image of the previously copied item
- Pasting into paint produces the new image that should have been saved...
(3,447 Views)
Accepted by topic author jrveale
I think you might be out of luck using the Clipboard:Get Image function. The help for the function states it doesn't work in the RTE:
You may be able to use some other method of querying the clipboard (.NET?), but I'm unsure off the top of my head.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,402 Views)
Thank you very much, Michael! I'm surprised I missed that...
This certainly gives me an avenue to explore at least!
(3,385 Views)
I wonder if you could just flatten the image data to a string and use the Clipboard Read and Write methods? Those seem to be supported under the RTE.
(3,378 Views)
I've just found this: someone's .NET workaround for this exact issue.
Later in the thread the marked solution states that a change in execution is also required.
I'll try it now and see if it makes a difference!
(3,373 Views)
For future reference, the attached project / build works nicely.
Note that under Take Snapshot.vi's VI Properties->Execution, Preferred Execution System is set to User Interface. This is required for the .NET Image.Save call to work.
Thanks for the help!
(3,360 Views)
