Different Filters
Alright. I added FIRs to different types of filters, as seen in the attached file. The waveform looks pretty weird. Have I done anything wrong, the connection or something???
(3,908 Views)
the input to the FIR VI is a waveform but you have wired an array of DBL. Hence the FIR VI is not able to perform filtering correctly. So after the filter VI use a build waveform function and using the input waveform as the "waveform' input and the output of filter VI as the 'Y'. Wire the output to the FIR VI.
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,897 Views)
(3,897 Views)
 I modified the VI alredy.The problem is that you cannot to the DBL type  instead of waveform type.See the attached file.
regards.
S.Ahmad
(3,852 Views)
Hi S.Ahmad,
I'm using labview 8.5 only and I couldn't open your file. can send again?
(3,785 Views)
Accepted by gareth1983
(3,767 Views)
thanks a lot mathan..
(3,748 Views)
