Device Register Map
Hi -
I am interested in the device register map for the NI PCIe-6353 DAQ card (and newer X-series cards).
Where may I find this documentation?
Thanks.
Message 1 of 8
(4,775 Views)
Hi yapatel,
what kind of map do you need?
Don't you find all relevant information in the manual?
Message 2 of 8
(4,768 Views)
No, the manual only shows the basics of using the card. I need register addresses, bitfields, etc.
Message 3 of 8
(4,759 Views)
Hi yapatel,
the manual explains all specs of the card. It mentions all inputs/outputs.
What kind of registers/ bitfields do you need? You need to use DAQmx to use that card…
Message 4 of 8
(4,757 Views)
No, the manual does not provide all the necessary informaiton for writing a driver for the card.
Message 5 of 8
(4,755 Views)
Hi yapatel,
why do you need to write a driver for that card?
Use DAQmx as it is provided by NI!
Message 6 of 8
(4,751 Views)
Accepted by yapatel
You already got an answer to this: http://forums.ni.com/t5/Multifunction-DAQ/Linux-Drivers-for-PCI-PCIe-USB/m-p/2829370
Please post related questions to the ddk board as it is not at all related to LabVIEW.
Message 7 of 8
(4,736 Views)
Thanks - I had not seen that someone had responded to that original request.
Message 8 of 8
(4,728 Views)
