Determine the maximum and the minimum value for each value of 2D array
Find a solution, but it only works for the first column of the array, I need that works for all columns of the array. Annex I solution
Message 11 of 43
(1,755 Views)
The arrangement with which I am working on is 2D arrays, WaveformData. In this arrangement need to extract the maximum and minimum of each element and form two arrays, one for maximum and another for minimum.
Message 12 of 43
(1,755 Views)
Hi Redney,
a simple way to get the maxima and minima of each row in a 2d array would be:
Use a TransposeArray to get min/max of columns...
"need to extract the maximum and minimum of each element"
You should define what an element is to you. Usually an element of an array is a scalar value - thus the maximum nd minimum of an element is the same as the element...
Message 13 of 43
(1,753 Views)
The maximum and minimum arrangement is shown as a partial solution that implements only works for the first column and not the rest.
Message 14 of 43
(1,752 Views)
Hi Redney,
still it's very vague what you really want to achieve.
Next try:
Message 15 of 43
(1,750 Views)
Redney, please give a example of the input and the expected output...
For example if the input is
[[1, 2, 3],
 [4, 5, 6],
 [7, 8, 9]]
What is the output?
Message 16 of 43
(1,757 Views)
What I need to get is the maximum and minimum of each array element. Each array element is a value in a waveform, at time t. I need to get the minimum and maximum value of each element after a time interval. Each of the maximum and minimum would be part of an array of other maximum and minimum.
Message 17 of 43
(1,755 Views)
Hi Redney,
as said before:
- You should define what an element is to you. Usually an element of an array is a scalar value - thus the maximum and minimum of an element is the same as the element...
- Wouter asked "What is the output?"
Message 18 of 43
(1,754 Views)
I know what is an element of an array. I need to get the maximum and minimum value of the variation of this element in time, you know.
Message 19 of 43
(1,742 Views)
The input is an array of 4 rows by 25 columns. Each element of this arrangement describes a waveform, what I need is to get the maximum and minimum values ​​of that waveform.
Message 20 of 43
(1,740 Views)
