Determine the maximum and the minimum value for each value of 2D array
Hi Redney,
it's not clear what you're referring to with "this is the best solution"...
"How do I get the array in t-1"
Well, you made that example with "array in t" and "array in t-1". So I suspect you already have those two arrays. Otherwise use a shift register (or a feedback node)...
Message 31 of 43
(1,975 Views)
Thank you for your help. I meant the best solution as I show below. Just do not know how to get the array at t-1.
Message 32 of 43
(1,969 Views)
How I can get the array at t-1
Message 33 of 43
(1,968 Views)
Please help me. I don´t find a solution to mi problem yet.
Message 34 of 43
(1,966 Views)
Attached is some code which will create the arrays I think you want.  Note the shift register is used to retain the previous new data for the next step through the FOR loop.  5 second wait between iterations to look at array elements.
Randall Pursley
Message 35 of 43
(1,962 Views)
Let me explain in detail, is that I need a lot of the solution to this problem. I have an array of sensors, consisting of 4 row and 25 columns. I need the maximum and minimum value measured by each sensor at a time delta t. I'm working with Labview 2011. The array with the need to work is wavelength data, you can see in the attachment image . Also sent them the vi for review.
Message 36 of 43
(1,953 Views)
Now send the picture.
Message 37 of 43
(1,952 Views)
I rewrote it based on what I think you are looking for.  Connect this VI to WavelengthData and the outputs should be the array of Maximum Values and Minimum Values over time.  Internal feedback nodes keep the latest copy of the Max and Min arrays for the next time the VI is called.  If this isn't what you need, then you need to explain it a little better.
Randall Pursley
Message 38 of 43
(1,942 Views)
"I have an array of sensors, consisting of 4 row and 25 columns"
So you have 100 physical sensors, each with their own waveform of data?
Message 39 of 43
(1,937 Views)
Yes i have 100 sensor, each with your own waveform.
Message 40 of 43
(1,905 Views)
