Retrieve floating point data with an sql select statement
Hi
I'm quite new to using sql but I have a system working where I can read and write strings to an access database.
Now I want to retrieve a a float, from a field where another field in the same post corresponds to a specified float, with a select statement.
When using strings I wrote
SELECT column_name FROM [table_name] WHERE column2_name='value'
in my query.
But instead of getting the desired value I get an error message telling me that I have a
"Data type mismatch in criteria expression".
I think I understand why but does anybody know what I should have written instead?
(2,744 Views)
Is the data type of column2_name String?  If it's not, I think the single-quotes you have around 'value' will cause that error.
Jim
(2,741 Views)
