Detecting if running from a packed project library or from run time engine
I just noticed this post:
https://forums.ni.com/t5/LabVIEW/failure-of-conditional-structure-RTE-check-in-packed-library/td-p/3...
I've got two ideas:
  • Check call chain (PPL)
  • Check the application path (EXE)
Is there anything more direct?
(2,498 Views)
I fail to understand what the problem is that you are trying to solve.  Are you trying to detect if code is in a PPL?  Or are you trying to get a path the a VI?
(2,450 Views)
"Running from a packed project library" and "Running from run time engine" are not mutually exclusive.
You can use a PPL from RTE or development environment.
So, PPL Y\N and RTE Y\N gives 4 combinations, and all 4 can happen.
(2,439 Views)
The App.Kind Propery Node returns:
  1. Development System
  2. Run Time System
  3. Student Edition
  4. Embedded LabVIEW (includes RT)
  5. Evaluation
  6. Custom
  7. (0) Invalid App Kind
=== Engineer Ambiguously ===
(2,429 Views)
Yes, that's correct. I was looking for something to let me distinguish the 4 possible states.
My call chain search to detect the PPL seems to be working but it felt very kludgey. and I was hoping someone had a more direct way.
  2. Run Time System
  3. Student Edition
  5. Evaluation
  6. Custom
Yes, that looks like a good way to get the RTE status. Thanks!
(2,410 Views)
Accepted by nanocyte
  2. Run Time System
  3. Student Edition
  5. Evaluation
  6. Custom
For the other property, this seems promising:
(2,371 Views)
That is the property I use in my Class Factory to determine if I am using a PPL or not.  I am then getting the folder of the library/PPL in order to load up the desired class using a relative path (relative to the parent class's path).
(2,362 Views)
