Design 3 value with 1 indicator
Hello All,
I have a problem with ic gates program, how these combine it with the value knob on labview program
This program have a 3 value but with 1 indicator,
I want to build,
Knob 1. When the knob value is greater or equal 0>= lamp on, when value greater or equal >=5 lamp off, and when value greater or equal  >= 9 lamp on again,
Knob 2. When the knob value is greater or equal 0>= lamp off, when value greater or equal >=5 lamp on, and when value greater or equal  >= 9 lamp off again,
I waiting your help guys,
im use 2013 labview version
Thank,
Stewkidz
(5,243 Views)
Accepted by StewKidz
Use In Range and Coerce Function or boolean functions
(5,236 Views)
As was said, the In Range And Coerce with another comparison and an OR will get you there.
(5,224 Views)
@StewKidz wrote:
Hello All,
I want to build,
Thank,
Stewkidz
First set the priority and Use  between three Points
 Use Select switch and Feed Boolean Inputs to decide ON or OFF
(5,223 Views)
Mr Artem.SPb and Mr Crossrulz
Thanks you very much for your help,
Before i build it with"formula node"
Now the program is so simply with "In Range and Coerce FunctionSmiley LOL
Thank,
Stew kidz
(5,212 Views)
Go through the attached sloution. it may helps you.....
NI CLDlabview-programming-fundamentalslabview-environment
(5,195 Views)
