10-16-2011 05:03 AM
Dear Chris and Jarrod:
I modified the vi you posted to use in deleting group data.
For the first time, it seemed to be success but I found malfunction of DeleteData.vi.
The vi deleted almost all groups (sometimes all, sometimes partly) in continuous executions.
(First, tried to delete 12000_0 then 7000_1. I got the after.png)
Can you recommend how to modify it?
labmaster.
05-14-2012 10:33 AM
The Strip Path Extension_ogtk.vi seems to be missing from that zip file. Do you know where I can get it?
Donners
05-15-2012 10:15 PM
Hi Donners,
I can't say for sure if this is what you need, but a file with the same name is discussed here.
http://forums.ni.com/t5/LabVIEW/Access-to-Application-ini/td-p/137586
Hope this helps!
Cheers,
04-04-2019 02:55 PM
In case anyone comes across this today, there is a now the TDMS Delete Data VI.
