Delete Child Class from a Parent Class
Hello All,
    I'm confused where to find the option to remove a child class from its parents class.
I see that I can change it's Inheritance (as seen in the attached picture). However, I do not see the option to remove let's say the AOP.lvclass from the Tests.lvclass
Reading through previous threads, it seems like this task is very unclear. Though I hope there's a simple solution that I just overlooked.
OJwithPulp
Message 1 of 9
(4,883 Views)
The parent has no clue about any of the children that inherit from it.  You have to make the change to the child class.
Message 2 of 9
(4,866 Views)
Accepted by topic author OJwithPulp
@OJwithPulp wrote:
Hello All,
OJwithPulp
Try changing its inheritance to the LV generic class and save all.
Ben
Message 3 of 9
(4,863 Views)
Thank you to both " and
Message 4 of 9
(4,825 Views)
@OJwithPulp wrote:
You should not have had to change its inheritance in order to delete the class from the project.
Message 5 of 9
(4,817 Views)
@crossrulz wrote:
Wasn't that changed in an early version of LVOOP?
Ben
Message 6 of 9
(4,814 Views)
@Ben wrote:
Ben
I don't know about the early days of LVOOP (it was a long time before I started to dive in).  But at least recently, I deleted a class from my project that did not use the LV Object as its direct ancestor.  If the parent actually cared, then I could see an issue.  But the parent has absolutely no clue who inherits from it.
Message 7 of 9
(4,804 Views)
Well, this is what was happening to me before (see pictures). I would try and remove a class from the labview project and it wouldn't work in the sense that It can still be seen under the Test Parent Class.
Message 8 of 9
(4,789 Views)
It would still be there if it was still in memory due to a previous run of your software that used it.  If you closed the project and opened it back up, it should be gone.
Message 9 of 9
(4,769 Views)
