Default Administrator password for Windows XP PXIE-1062Q Controller
My PXIE controller was installed and setup with LabView (I assume) at NI. The OS is Windows XP,  what is the Administrator password that was set during this process? ie how can I log in to the controller for the first time.
Ian
(3,989 Views)
Accepted by topic author NUFC
Try this:
http://www.mydigitallife.info/2006/11/25/easily-login-to-windows-xp-with-no-password-administrator-a...
Basically you press ctrl-alt-del twice when you get the login screen. Hopefully the administrator password hasn't actually been set, so you can just press ok or enter.
This is what I found on two used PXI systems that I bought at auction.
Because this is so simple I would strongly recommend setting an admin password as soon as you can.
(3,978 Views)
