10-12-2008 11:16 PM
10-14-2008 01:56 PM
Hello wer12,
This is an interesting question. The point of this function is to return the closed loop model from two other specified models. It is a mathematical transformation to find the value you are looking for, give me some time so that I can double check my math. I am curious as to why you are interested in this value?
I will post back when I have more time to investigate the VI you posted.
Angela M
Product Support Engineer
10-14-2008 06:14 PM
Hello wer12,
I have been looking into this in more detail and I think you would be better off to not reduce your transfer functions using the CD Feedback.vi if you are interested in this error value. This VI implements a model reduction and does not make available the information you are looking for.
If you have 2 transfer functions that you want in a feedback loop, you could easily implement a feedback loop in simulation. In simulation you would have access to your input, your output and error values. If you reduce the model using CD Feedback you would only have access to your input and output values.
I hope this helps, please let us know if you have further questions about this.
Angela M
