‎04-11-2026 03:10 AM
Hello everybody,
I would like to create a little system using LabVIEW to decode the signals from the IR remote controls that we usually have for TVs and air conditioners.
What I have is:
- TSOP38238 IR receiver https://www.vishay.com/docs/82491/tsop382.pdf
- NI PCI-6220 I/O card https://www.ni.com/docs/en-US/bundle/pci-pxi-6220-specs/page/specs.html?srsltid=AfmBOoqlwlyOpdytlN1X...
- LabVIEW 2022 Q3 Professional Development System
The cable from the card is going to a perfboard, so it would be easy to connect the IR receiver to the PCI-6220.
The first thing that I need to know is if the TSOP38238 can be connected directly to the card, and if yes to which pins.
Then I would need to know which LabVIEW function would be best to use, assuming there is already something ready for this purpose.
Thanks in advance
Max
‎04-12-2026 12:23 PM
The question must be either too dumb or too difficult, can't tell which of the two.
‎04-12-2026 03:08 PM - edited ‎04-12-2026 03:10 PM
Hi Max,
It's weekend and it's our spare time we use to write answers...
Yes you can connect the sensor to your DAQ card.
‎04-12-2026 03:36 PM
Sorry, my doubt was because I'm just a software developer without any electronic knowledge, that's what I meant.
No hurry here.
Good to know that it is possible.
So if I understood correctly.
Pin3 TSOP -> Pin8 NI Card (5V)
Pin1 TSOP -> Pin52 NI Card (P0.0 DI input)
Pin2 TSOP -> Pin18 NI Card (D GND)
My main doubt was about the use of Port 0 (P0.<0..7>) or PFI/Port 1/Port 2 Functionality.
The transmission should be very fast, I thought the latter had more chances to get the job done.
But again, I’m no expert, so I might be talking a load of rubbish.
‎04-13-2026 12:59 AM
Hi Max,
You should use the "waveform characteristics" (aka Port0) to read digital waveforms with higher sample rates.
(I don't think you want to use the PFI for "timing input".)
‎04-13-2026 07:14 AM
Thank you very much!
If port0 is suitable for the purpose, that's great!
Any hint about an example VI, if any, nearly ready for this job?
Thanks again
Max
‎04-13-2026 07:20 AM
Hi Max,
LabVIEW/DAQmx comes with a huge library of example VIs: just open the example finder!
‎04-13-2026 12:59 PM
As an alternative to rolling your own completely from scratch and using a PXI DIO module with timing support (sounds expensive as a solution), have you looked into some of the third-party specialty hardware in the IR communications space? There was a poster on here years ago who was experimenting with a device from RedRat that may be considerably less expensive and offer support via .NET. They've already done the non-trivial design work of integrating both an IR detector and emitter, with biasing/driving circuitry. The emitter could be handy if you should decide you want to send commands as well.
Dave
‎04-13-2026 03:46 PM
Yes, I looked into third-party solutions... but since I already have the PCI card and the IR receiver mine would be a cost-free solution.
But it's not only a matter of cost.
Being myself a LabVIEW developer it's also the thrill of the challenge!
Max
‎04-13-2026 07:24 PM
I think I realized this, belatedly, when I went to look up that module (to see if it supported timed capture). Saw that it’s already been obsoleted, so the cost clearly wasn’t a factor.
Good luck with your project! Hopefully Vishay offers some example circuit diagrams - I’d be really surprised if it’s quite as simple as +5V, return, and a buffered logic pin connection. But perhaps the part has all the internal AGC, Schmidt triggering etc built in?
You may still find some items of interest on the RedRat site. As I recall, there is a lot of variety in different vendors’ encodings after you get past the 38 kHz pulse chain. RedRat has some sort of downloadable database of encodings.
Best of success to you!
Dave
