04-11-2026 03:10 AM
Hello everybody,
I would like to create a little system using LabVIEW to decode the signals from the IR remote controls that we usually have for TVs and air conditioners.
What I have is:
- TSOP38238 IR receiver https://www.vishay.com/docs/82491/tsop382.pdf
- NI PCI-6220 I/O card https://www.ni.com/docs/en-US/bundle/pci-pxi-6220-specs/page/specs.html?srsltid=AfmBOoqlwlyOpdytlN1X...
- LabVIEW 2022 Q3 Professional Development System
The cable from the card is going to a perfboard, so it would be easy to connect the IR receiver to the PCI-6220.
The first thing that I need to know is if the TSOP38238 can be connected directly to the card, and if yes to which pins.
Then I would need to know which LabVIEW function would be best to use, assuming there is already something ready for this purpose.
Thanks in advance
Max
04-12-2026 12:23 PM
The question must be either too dumb or too difficult, can't tell which of the two.
04-12-2026 03:08 PM - edited 04-12-2026 03:10 PM
Hi Max,
It's weekend and it's our spare time we use to write answers...
Yes you can connect the sensor to your DAQ card.
04-12-2026 03:36 PM
Sorry, my doubt was because I'm just a software developer without any electronic knowledge, that's what I meant.
No hurry here.
Good to know that it is possible.
So if I understood correctly.
Pin3 TSOP -> Pin8 NI Card (5V)
Pin1 TSOP -> Pin52 NI Card (P0.0 DI input)
Pin2 TSOP -> Pin18 NI Card (D GND)
My main doubt was about the use of Port 0 (P0.<0..7>) or PFI/Port 1/Port 2 Functionality.
The transmission should be very fast, I thought the latter had more chances to get the job done.
But again, I’m no expert, so I might be talking a load of rubbish.
04-13-2026 12:59 AM
Hi Max,
You should use the "waveform characteristics" (aka Port0) to read digital waveforms with higher sample rates.
(I don't think you want to use the PFI for "timing input".)
04-13-2026 07:14 AM
Thank you very much!
If port0 is suitable for the purpose, that's great!
Any hint about an example VI, if any, nearly ready for this job?
Thanks again
Max
04-13-2026 07:20 AM
Hi Max,
LabVIEW/DAQmx comes with a huge library of example VIs: just open the example finder!
04-13-2026 12:59 PM
As an alternative to rolling your own completely from scratch and using a PXI DIO module with timing support (sounds expensive as a solution), have you looked into some of the third-party specialty hardware in the IR communications space? There was a poster on here years ago who was experimenting with a device from RedRat that may be considerably less expensive and offer support via .NET. They've already done the non-trivial design work of integrating both an IR detector and emitter, with biasing/driving circuitry. The emitter could be handy if you should decide you want to send commands as well.
Dave
04-13-2026 03:46 PM
Yes, I looked into third-party solutions... but since I already have the PCI card and the IR receiver mine would be a cost-free solution.
But it's not only a matter of cost.
Being myself a LabVIEW developer it's also the thrill of the challenge!
Max
