Decode a serial protocol
Hi Elham,
of course not )
I just hoped that there's progress on main problem of topic.
Yuriy
Message 31 of 35
(1,533 Views)
Yeah ,Actually I also thought it might be ,but now I got they are not the same topics.
@Yuriy007 wrote:
Hi Elham,
i was thinking this topic is about decoding of digital Colotronic LOAD CELL protocol, but as i see you try to decode some battery cell serial protocol.
Yuriy
@Yuriy007 wrote:
Hi Elham,
Yuriy
Message 32 of 35
(1,533 Views)
Finally I measure the baudrate which is 8928,and I used a piece  code in Matlab so I collect the transfered data from modules to the controller.all of them are decimal numbers.anybody have any suggestion how to decode it,or be sure that they are the correct data since I do not have any information about parity and stop bit but I also will try to to change them, and see the results.I just think that by chaging and discharging the battery and see the changes on these values maybe I can recogoniyed the relation between those values and the temperature,voltage an current.
thanks
elham
Message 33 of 35
(1,518 Views)
Hello  s224683,
I suggest you start a new topic since the original one is from 2010 and you are discussing different subjects.
Regards.
Message 34 of 35
(1,502 Views)
baud rate 9600
date bits 8
stop bit 1
parity even
ms byte first
i'm have colortronic modbus problem also
Message 35 of 35
(1,204 Views)
