11-26-2010 01:53 AM
Hi every@ll,
I have developed an application in Labview v8.6 ActiveX used to call the MATLAB software (by MatlabScriptNode) and a small program run well with the rest of Labview code.
Under Labview everything works fine but when running the application. Exe generated with Aplication Builder is not true. Everything works except when the call is made to MATLAB.
I tried to use Debug Aplication from localhost to find the problem but when run will not let me browse and select menus I have in the developed application. This issue is another detail I'd like to find. How to handle menús in debug aplication?
11-26-2010 02:49 AM
I don't clearly understand what you are doing :
Are you using a Matlab ActiveX called by LabVIEW ? Are you using a remote front panel ?
How are you handling erros in your application ? You should maintain dataflow in order to know if an error occurs in your application and the you'll be able to debug it.
Can you post your VI or an example that would reproduce your issue ?
11-26-2010 05:21 AM
i explain you:
I have a mean program VI working fine with deveploment (inside has Matlab ActiveX called by LabVIEW) . When i build the executable with aplication builder all works correctly excepts the part where calls matlab file.
I dont hand errors because doesn´t crash but not working as expected (performs others cases of code that sholudn't occur). I think the problem is related to the paths, i mean the fail is when build the .exe file.
For this reason i want to debug to see the blocks diagram and check the paths used when the Matlab Call occurs. But in debug mode from localhost (remote front panel in the same pc) doesn´t let me navigate over menus that i have created. However, i can handle menus perfectly running the build executable.
I'll try to upload a file example later
11-30-2010
03:16 AM
- last edited on
09-23-2026
07:32 AM
by
Content Cleaner
Hello Squal,
To debug executables, just follow the indications of these links (to debug local or remote executables):
http://digital.ni.com/public.nsf/allkb/3087D91EEADBAF3D862571D1004AF192?OpenDocument
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHpiCAG&l=en-US
However, if the problem is with the ActiveX control, there are a number of different reasons that ActiveX objects may not work. This KnowledgeBase gives a few ideas to try before contacting Technical Support.
1. Ensure that your VI is working without any errors. It may even be worth checking for warnings too. One way to check for warnings would be to place a probe on the error cluster in the VI and monitor what happens or comes through.
There are a number of ActiveX warnings and these may be causing problems when the application is deployed.
2. Check that there are no programs stopping ActiveX programs from running. These can include any of the following: Anti-virus programs, Firewalls, Network policies, Windows Defender and Windows Firewall.
If any of these pieces of software are installed, check their settings and verify that they are not interfering with the ActiveX execution.
3. Also try registering the ActiveX program with Windows. If you want to do this dynamically at run time, use the System Exec VI to do this.
11-30-2010 04:34 AM - edited 11-30-2010 04:38 AM
Hi again,
At the first I followed always the indications of these links and i can debug the local executable but with the inconvenience that doesn´t let me hands the menus toolbar. Everything works fine unless this detail so i can´t show the blocks panels of sub vi i'm interested to check.
By the other way there can´t be programs stopping ActiveX programs from running because it works under the file.vi correctly.
I want to know the reason that doesn´t appears the menus:
I'll try to check the other options in next days
11-30-2010 06:35 AM
The following list contains some guidelines or steps you can follow to view custom run-time menus when debugging:
The attachment shows one possible solution using a Flat Sequence structure. The code before the Flat Sequence structure sets a customized run-time menu and checks whether you can remotely debug the application. The first frame of the Flat Sequence structure guarantees a specific entry point during debugging because of the restriction that it is not allowed to use the Wait for debugger on launch option. You can add your code to the second frame of the Flat Sequence structure. Also, notice the Start Debugging control. Ensure that the Start Debugging control is not hidden when you build the VI. In this example, the programmatically processed menu entries are not affected.
12-01-2010 02:55 AM - edited 12-01-2010 03:03 AM
Hi, I found the cause of the error. This was the path to the directory where the file requesting (process.m)
Processv.m is created with aplication builder in c:\documents and Settings\Lan\Escritorio\Install tometor\SETUP\APP but when it's created, the path change to "c:\documents and Settings\Lan\Escritorio\Install tometor\SETUP\APP\tometor.exe" instead "c:\documents and Settings\Lan\Escritorio\Install tometor\SETUP\APP\" (i don´t know why because in the VI worked fine).
I had to add another "strip path" while running directly the VI file didn't generated errors, I mean the path was correctly indicated but when i built de aplication.exe didn't work.
Thanks all
12-01-2010 08:39 AM
That's a classical problem, when built into an executable, the .exe name works like a folder (you can consider it as all VI's being compressed into a .exe), thus, if you access a file outside the project you'll have to handle an extra folder.
The benefit of the system is that all VI's that are 'compressed' this way works.
/Y
