Dear friends, need help with basic Integration problem.
Dear friends,
I am trying to solve an integration problem similar to the attached one. This is the first time I am trying to solve integration problem using LabView, I am not even sure which package is appropriate to solve this problem. FYI, I am using LabView 2018 student version. Please give your opinion, your time and advice is greatly appreciated.
Thank you and have a good one.
Message 1 of 10
(4,319 Views)
The only thing worse than a .PNG Image is a .JPEG Image, which I won't ever try to open.
Message 2 of 10
(4,257 Views)
sorry about that
Message 3 of 10
(4,247 Views)
@Forhad wrote:
sorry about that
I guess you've moved up to second worst.  Bob is trying to get you upload the actual problem code, meaning the VI.
Bill
CLD
(Mid-Level minion.)
Message 4 of 10
(4,243 Views)
Message 5 of 10
(4,224 Views)
That is now an embedded picture.  But still no VI was attached.
Message 6 of 10
(4,212 Views)
Hi, I don't have any vi now. I am not even sure which package to use to solve this integration problem.
Thank you
Message 7 of 10
(4,206 Views)
One of your images shows the block diagram of a VI.
Bob_Schor frequently (and sensibly) requests such VIs be attached to forum posts, rather than screenshots etc, because it makes it much easier to download, test, explore and/or correct a problematic VI.
Without an uploaded copy, forum users must attempt to recreate your VI (perhaps not so bad here, but in any case) and hope that they don't, for example, accidentally correct your mistakes (as might happen if the problem is a minor misconnection or similar).
Hopefully this makes the request's purpose a little clearer.
GCentralI'm attending the GLA Summit!
Message 8 of 10
(4,198 Views)
  1. Open LabVIEW.
  2. On Menu Bar, click Help.
  3. Click LabVIEW Help ...
  4. In Search Box, type "Integration".
  5. Look at the first few entries, see if any seem appropriate.
  6. Read the Detailed Help for the topic you chose.  If it seems relevant, note the "Owning Palette", as this will help you find the function(s) on the Block Diagram set of Palettes (what you see when you right-click on the Block Diagram window).
  7. Check out any examples mentioned at the bottom of the Help.
Once you've done that, try writing your own VI.  If it doesn't work, come back here, tell us what you tried, and attach your VI.
Message 9 of 10
(4,192 Views)
There is probably a better way to do this, but here is a start for the denominator.
Mathematica result shown also for verification.
mcduff
Message 10 of 10
(4,180 Views)
