10-10-2019 02:06 AM
Dear friends,
I am trying to solve an integration problem similar to the attached one. This is the first time I am trying to solve integration problem using LabView, I am not even sure which package is appropriate to solve this problem. FYI, I am using LabView 2018 student version. Please give your opinion, your time and advice is greatly appreciated.
Thank you and have a good one.
10-10-2019 08:13 AM
The only thing worse than a .PNG Image is a .JPEG Image, which I won't ever try to open.
10-10-2019 08:35 AM
sorry about that
10-10-2019 08:39 AM
@Forhad wrote:
sorry about that
I guess you've moved up to second worst. Bob is trying to get you upload the actual problem code, meaning the VI.
10-10-2019 10:14 AM
10-10-2019 10:52 AM
That is now an embedded picture. But still no VI was attached.
10-10-2019 11:10 AM
Hi, I don't have any vi now. I am not even sure which package to use to solve this integration problem.
Thank you
10-10-2019 11:27 AM
One of your images shows the block diagram of a VI.
Bob_Schor frequently (and sensibly) requests such VIs be attached to forum posts, rather than screenshots etc, because it makes it much easier to download, test, explore and/or correct a problematic VI.
Without an uploaded copy, forum users must attempt to recreate your VI (perhaps not so bad here, but in any case) and hope that they don't, for example, accidentally correct your mistakes (as might happen if the problem is a minor misconnection or similar).
Hopefully this makes the request's purpose a little clearer.
10-10-2019 11:39 AM
Once you've done that, try writing your own VI. If it doesn't work, come back here, tell us what you tried, and attach your VI.
10-10-2019 11:58 AM
There is probably a better way to do this, but here is a start for the denominator.
Mathematica result shown also for verification.
mcduff
