Data to spreadsheet
Hallo.
I have a big problem with exporting data out of the loop in the attached VI. It is namely "speed" data I want written to a data sheet. I've tried looking around the forum, but have unfortunately not been successful in finding the answer. thank you in advance
By the way, i am using a MyRIO if the makes a diffrence.
(3,434 Views)
Hi AAU,
the most easy way should be this: check.png
When you execute this on a myRIO you should not forget you are writing to the internal flash drive of the myRIO! Don't use a path pointing to your PC's harddrive!
P.S.: Attaching scaled images is kind of silly…
(3,412 Views)
Thanks a lot
but when I use the solution I get an error (shown below)
has it something to do with the path I save in? I appreciate the help!
(3,408 Views)
Hi AAU,
which path are you trying to use? Don't you pressed the cancel button?
(3,384 Views)
You have to specify a path on the block diagram.  The myRIO doesn't actually have a GUI, so you can't browse for a file location.  You have to specifiy it ON THE MYRIO ITSELF, NOT ON THE PC.
(3,353 Views)
