repair labview runtime LV2012 SP1 F7
HI
I have a problem with LV2012 SP1 RTE, when i run any exe using LV2012 the RTE opens and immediatley closs with no error. I never see a front panel. MAX is showing I have LV2012 SP1 F7.  Has anyone ever seen F7?   I have re-installed LV2012 dev system and LV2013 SP1 dev system and the RTE is still broken.  I can run exe's built in LV2011 and LV2013
My Max:
So, any idea where i find a distributin to reinstall 2012 SP1 F7?  i cannot install f5, it tells me a higher version exists.  I am stuck as i have been reinstalling and repairing installations all day now.
Thanks!
Michael.
(2,531 Views)
Hi Michael,
Please accept my apologies for your delays in getting a response.
Are you still having issues with your RTE installations?
I have a system here which is completely up to date and the latest version of LV RTE 2012 SP1 is f5 which leads me to believe that the source of the issue is not a 'corrupt' installation of f7, but that the system is recognising your versions numbers incorrectly.
Do you have an entry for any LabVIEW Run-Time Engine 2012 SP1 in your list of software should you select to Uninstall under 'Programs and Features' in your Control Panel?
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,404 Views)
Chris, this is solved. Another user had exact issue on the same day so we used his post and just left this one. I got the msi for f7 from r&d and this fixed it for me. Thanks
Michael
(2,398 Views)
