Data base and labview
hi everyone,
i have a Data Base created with Microsoft SQL Server, i want to create a connection with labview. The Data base have an .mdf extension , can u guys help me with an example to connect and to read & write data using labview
thnks
Message 1 of 12
(4,638 Views)
Everything you want to know about connection string (and a lot you don't want to know) can be found here:
https://www.connectionstrings.com/sql-server/
As for an example, what toolkit are you using?
Message 2 of 12
(4,602 Views)
 Follow the below two steps to read / write between MSSQL Server and LabVIEW.
1. Create ODBC connection.
2. Use LabVIEW Database Connectivity Toolkit to Read / Write (Refer Example code).
Sivaraj M.S
CLA
Message 3 of 12
(4,588 Views)
thnks for the answers, i tried to create an UDL, Select "Tools" and "Create Data Link",  but when i select the provider which is SQL Server Native Client 10.0 and after that i click "refresh" i don't find the server. Any explanation for that??
PS : the statut of my server is "connected" Microsoft SQL Management Studio
Message 4 of 12
(4,569 Views)
Type it manually. That happens to me also. Just type the name of the server, as it appears when you open SQL Management Studio. Then
proceed filling up the rest of the fields. If the server is read correctly, tables should appear on the field.
Message 5 of 12
(4,556 Views)
hi JLuna,
i tried to type it manually but nothing changed 😞 , the DATABASE didn't appear on the field . what should I do???
Message 6 of 12
(4,530 Views)
He mend (I think) to open an example, and manually edit the connection string in the VI.
Message 7 of 12
(4,527 Views)
hi wiebe@CARYA
no i don't think so, he mend to type the server manually in the fields of getting the UDL file in the tools
Message 8 of 12
(4,517 Views)
Well, since that's not working, you might try the other way.
Message 9 of 12
(4,505 Views)
i don't unterstand , the server is connected in sql management studio but it doesn't appear in labview when i want to create the UDL link, i tried to type it manually but nothing changed . i'm blocked :'(
Message 10 of 12
(4,502 Views)
