Data Saving
Hallo,
I need to save all data from a cluster, which is generated by the producer loop continuously. This data cluster contains about 20 nummeric elements, which represent different types of parameter. I want to save these data with heade
Is there any advice for the data saving?
Best regards
CLAD Certified
(3,635 Views)
 Do you need those data files later on for LV only only is it planned to read these files from other applications as well (e.g. DIAdem)?
Norbert
Expert: Geometry
(3,628 Views)
Hallo Nobert,
Thanks for your reply.
DIAdem maybe not. But I will certainly use it in Matlab and LabVIEW.
Best regard
CLAD Certified
(3,618 Views)
Clusters can be directly written into Datalog Files. This however is a file type which is LV proprietary and cannot be used with other tools.
So the first question you have to answer is how the file shall look like as such that LV and Matlab can access them.
Once you know this, we can help further. You should also use google (or other search engine) to look if there are free-to-use APIs for file types you want to take a check on.
Norbert
Expert: Geometry
(3,612 Views)
Accepted by TUDarmstadtLLX
finally I chose to use save data in txt format. I have changed the cluster into array and then give every element a header.
Best regard
(3,535 Views)
