intensity graph
Hey, I'm new to labview and am hoping someone can help me, i need to draw this using only the intensity graph please if someone know how to draw if leave a comment
(3,093 Views)
Hi aguemech,
Who gave you this order/requirement? Can't you ask them?
General advice on your screenshot:
- I would use a XY graph or a 2DPictureIndicator, both allow to "draw" lines and circles.
- Do you also need to draw those axis and "80mm" texts? Then use a 2DPictureIndicator as it provide ready-to-use functions…
- If you insist on using an intensity graph: create a 2D array with your "image" and set the elements as needed. You need to implement your own "drawing" routines!
(3,037 Views)
Use the 2D picture vis to create the picture (or use the one provided as a constant or load it 🙂 )
and wire it into the intensity graph, use the properties of the graph to scale it 🙂
(bonus: read the screen properties and really scale it to 80mm :D)
and no need to cut the picture , just change the xy ranges 😄
Greetings from Germany
Henrik
LV since v3.1
(3,031 Views)
