Data Entry Tab for Numeric Indicator does not Exist
Hi
I'm trying to set the data range for numeric indicators on LabVIEW 10.0.1. For some reason when I go to properties of my numeric indicator, there is no Data Entry Tab as explained on the NI website: http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/changing_data_ranges_of_nu/. Also, in the data type tab, there is a section for range but everything is grayed out. Any help is appreciated. Thanks
Message 1 of 8
(3,490 Views)
Why would there be data entry tab for an indicator?
Message 2 of 8
(3,482 Views)
In addition to it being an indicator there seems to be another problem.
a 0 bit length Fixed Point is a rare animal indeed!  Is this some object that has gone insane?  Can you post a snippet of that critter?
"Should be" isn't "Is" -Jay
Message 3 of 8
(3,479 Views)
Jeff,
It is an I32 and not a fixed point and that is why everything under the fixed point configuration is greyed out and meaningless.
Message 4 of 8
(3,473 Views)
@Dennis_Knutson wrote:
Jeff,
Thanks- Missed that in the blur
Message 5 of 8
(3,464 Views)
Hi
Thanks for the replies
I just realized that data entry on a numeric indicator doesn't really make sense. But my question is, how do I go about setting data range for a numeric indicator? Based on this tutorial : http://www.ni.com/pdf/manuals/320998a.pdf (Page 128/250) in the older versions there seems to be a data range tab or option when you write click the indicator. In my case, the range is greyed out and I tried to play with it with no avail.
Thanks very much
Message 6 of 8
(3,437 Views)
Accepted by topic author Red_CCF
Digging up a very, very old manual (1996!) is not all that productive. If you want to restrict the output, simply use the In Range and Coerce function.
Message 7 of 8
(3,433 Views)
Hi
I just realized that the manual has a typo and they listed the wrong variable for me to change.
Message 8 of 8
(3,428 Views)
