Data Dashboard stops working when I remove my USB cable from the laptop
I have created a LabVIEW application (having host VI and an FPGA vi which runs in cRIO 9037), which I was trying to run using the Data Dashboard app instead of a laptop. In LabVIEW, I created the shared variables of all the control switches and indicators that I need, then I created a new real-time application and followed the following steps: Deploy>Build> Set as Startup> Run as Startup. With this, I can control my application using the Data Dashboard and visualize the data as well. However, when I remove the USB cable (which I used to connect my laptop to cRIO), the data dashboard app does not work. But, when I connect the USB back to my laptop, data dashboard works again.
I can't figure out what is going wrong.
(2,480 Views)
When you unplug the USB cable from the cRIO, do you have any Ethernet connection on the cRIO that would allow communication between the cRIO and laptop?
(2,460 Views)
No. There's no any other connection between cRIO and Laptop.
(2,454 Views)
So how do you expect Data Dashboard to get updated data when you break the only data communication path with the cRIO?
(2,433 Views)
My bad, I didn't explain it in detail. I have created a wireless network with cRIO 9037 through which I am able to communicate data dashboard to cRIO/Labview (I want to communicate/control wirelessly through ipad). When I deployed my code from my laptop to the cRIO, I was expecting that I can remove the USB and control fully wirelessly. But, when I remove the USB cable connected to laptop, my data dashboard doesn't work and when I plug the USB back, I can control wirelessly. I don't even need to open or run the code in laptop for the data dashboard to work, only plugging in the USB is enough.
(2,425 Views)
