03-13-2006 11:06 AM
03-13-2006 11:48 AM - edited 03-13-2006 11:48 AM
Message Edited by altenbach on 03-13-2006 09:59 AM
03-13-2006 11:55 AM
Good suggestion, altenbach. I'll put that one on the books and maybe we'll see it implemented in a future LabVIEW version.
-D
03-13-2006 12:17 PM
Hi Darren,
While you putting that one in the books, please take it one notch farther so it will swap inputs to a "Select".
Christian wrote;
"Ever notice how if you e.g. insert a divide operation into a wire, the input is invariably on the wrong terminal. "
Urs Lauterburg shared on Info-LabVIEW that it is possible to determine which of the two inputs gets wired when doing an insert. The trick is to hold the cursor a little above or below the wire.
If the cursor is slightly below, it wires to the top input. Vise versa for the bottom.
Ben
03-13-2006 12:31 PM - edited 03-13-2006 12:31 PM
Message Edited by jasonhill on 03-13-2006 12:33 PM
03-13-2006 12:37 PM
Epictetus
03-13-2006 12:42 PM
03-13-2006 12:51 PM
03-13-2006 01:51 PM
06-05-2006 08:13 AM
@altenbach wrote:
the true story is that I am typically don't really know what I have to divide by what, or what I am doing, so I just swap until the result looks right. But admitting that would make me look stupid....:o)
LOL!!
aLWAYS GOOD TO READ THESE.
OOps. Caps lock !
Now, it would be nice to have a feature which lets you select two terminals and switch them, instead of disconnect terminal, then connect to the right location. Or maybe there is...???....??? (future nugget?)
