Darren's Occasional Nugget 03/25/2014
I attended the European CLA Summit last week (my first trip outside the USA!). At the summit I gave a presentation that discussed, among other things, the VariantDataType VIs. Among the myriad use cases for these VIs is checking a variant to see if it matches a particular type. For example, we have a VI that ships with LabVIEW that will assess whether or not a variant is an error cluster (for reference, this VI lives in vi.lib\addons\analyzer\_analyzerutils.llb\VIAnUtil Check Type If ErrClust.vi):
In this VI, we check the variant to see (1) if it is a cluster, (2) if it has three elements, and (3) if those elements are Boolean, I32, and String (in order). I have often recommended this approach for type checking over a simple Variant To Data function call, since Variant To Data will attempt the conversion, even if the types don't match exactly:
Another great use case for these VIs is programmatically retrieving, at runtime, the names of enum entries as a string array:
The VariantDataType VIs are great for data type parsing, and these are just two of many use cases that demonstrate the power of this undocumented API. Have you encountered a novel use for the VariantDataType VIs in your applications?
Message 1 of 12
(14,425 Views)
Enum to string array, nice.  Is there a slide deck that you are able to post?
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 2 of 12
(14,385 Views)
Yup, you can get the presentation here.
Message 3 of 12
(14,381 Views)
Can we bring some of these functions into the "officially supported" set?
http://forums.ni.com/t5/LabVIEW/Make-VariantDataType-functions-officially-supported/td-p/2792204
I hope you don't mind I borrowed one of your images
CLED (2016)
Message 4 of 12
(14,275 Views)
Hi, I used to download MGI toolkit from VIPM and it has a palette for all the variant type stuff.
Message 5 of 12
(14,266 Views)
Darren,
that  was a great presentation at the summit in CERN.
Certified TestStand Architect
Message 6 of 12
(14,207 Views)
Variants are indeed very nice and powerful, i've made a general ini-file writer/reader through that.
It begs the question: Why are the functions hidden? The Variant palette needs fleshing out, if not in the direct palette, then in a "advanced" subpalette.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 12
(14,190 Views)
Same with OpenG which also has a Enum to String or String to Enum.  Still I'm in favor of native support over 3rd party when functionality is the same.
Message 8 of 12
(14,112 Views)
/Y
  1. Tools>>Advanced>>Edit Palatte set...(drink Coffee)
  2. Right click an open palatte position Insert>>Subpalatte:
  3. Check Link to a directory
  4. Browse to <LabVIEW> \vi.lib\Utility\VariantDataType
  5. Select Save
  6. select Continue
Whoomp! There it is:
Cross-Posted to uNuggets Thread since this comes up WAY TOO OFTEN.
"Should be" isn't "Is" -Jay
Message 9 of 12
(14,092 Views)
  5. Select Save
  6. select Continue
Not needed just install the package in the Package Network made by NI called Hidden Gems in vi.lib as mentioned at the end of the slides posted by Darren.
Edit:  Thank you by the way for making this a package.  I already have a vi.lib package with many of the things you mentioned in your slides but not all so this is easier.
Message 10 of 12
(14,071 Views)
