DMA Requested number of ele
HI ,
Just a simple question about DMA channel.
When im configuring an taget to host or host to target DMA ,
Data type is U16 , and requested num of elements is 1023 .
does it mean that the whole size of the fifo is 2Kbytes , each cell of the fifo is U16 data (2 bits ) ?
what exactly is element ?
Thank you.
(3,126 Views)
Usually "element" means "the basic Unit under discussion".  If you have a device that gives you Units of a 16-bit unsigned integer, then your Unit occupies two bytes.  Note, however, the first word in this response ...
(3,084 Views)
Accepted by topic author Cobmetal
The number of requested elements and the size of the individual FIFO reads are unrelated technically.
When you initialise a DMA FIFO, you can request a specific size before starting any Read operation.  This will be a multiple of the element data size (in your case 2 Bytes).  If you request a FIFO size of 8192 elements, then it will occupy 2x8192 Bytes.  Also note that LV cannot always comply with the requested number of elements, but I've never come across a case where it set a different size than I wanted.
LV typically defaults to one million elements for a FIFO IIRC.  Two factors are important here.
1) The size of the FIFO is required so that LV can do background transfers into a buffer, even if you're not currently reading
2) it's a good idea to have the size an integer multiple of your read size due to behaviour when overflowing the receive buffer
To add to the confusion, there's a Buffer size on the RT and on the FPGA side.  Both are completely independent of each other.  There's a great article on this somewhere..... HERE.
Edit: Clarification due to some mixing up of terms on my part.
(3,079 Views)
The data size of the fifo is 2Kbytes, each element of the fifo is U16 data (2 bytes (16 bits)).
(3,078 Views)
