10-03-2008 06:41 AM
I have this typical problem with PCI-DIO-96
When I tried to read few lines/port one port; some other port status are resetting,
For Eg I have PORT0/Line1,PORT1/Line1, PORT2/Line1 , PORT3/Line1 to ON condition.
In the next step when i try to read PORT0/Line4 &Line 5 , the PORT1/Line1, PORT2/Line1 line goes LOW.
I am not sure if this is anything to do with the MAX configuration or the device configuration.
Also I am not able to see the "properties" for this device in the MAX (it is grayed out/disabled)
This are my set up.
LV. 8.0.1
MAX 8.1,
OS , WinXP
I tried checking with another set up , but with same s/w configuration, with another card, the results are just same.
I have seen the same while trying with MAX test panels/Example etc
I have observed this issue probing at the card connectors , so the cables are out of scope.
Thanks in advance
10-04-2008 06:16 AM
Hi,,
It looks like there is H/W limitation to configure DIO in PCI -DIO -96 as input and outputs on the same port..
http://digital.ni.com/public.nsf/allkb/B0E19607502D8B3986256EBE000A9119
