DIO off while reading
I have this typical problem with PCI-DIO-96
When I try to read few lines/port one port;  some other port status are resetting,
For Eg I have PORT0/Line1,PORT1/Line1, PORT2/Line1 , PORT3/Line1 to ON condition.
In the next step when i try to read PORT0/Line4 &Line 5 , the PORT1/Line1, PORT2/Line1 line goes LOW.
I am not sure if this is anything to do with the MAX configuration or the device configuration.
Also I am not able to see the "properties" for this device in the MAX (it is grayed out/disabled)
This are my set up.
LV. 8.0.1
MAX 8.1,
OS , WinXP
I tried checking with another  set up , but with same s/w configuration, with another card, the results are just same.
I have seen the same while trying with MAX test panels/Example etc
I have observed this issue probing at the card connectors , so the cables are out of scope.
Thanks in advance
jemmy
(2,684 Views)
After many search I found that there is a H/W  limitation to do so
http://digital.ni.com/public.nsf/allkb/B0E19607502D8B3986256EBE000A9119
Regards
(2,680 Views)
