DIADEM Graph 3D
Help!
The aim is to load several signals on a preconfigured 3D graphs Diadem rapport.Concerning the Z-matrix, as the numbers of channels is variable I would like that the graph select automatically all the channel that are in a group.
Example:Signal 1X-Axis: Group 1 - Channel1Y-Axis: Group 2 - Channel 1Z-Matrix: Group 3: Channel 1 to Channel 10  Signal 2X-Axis: Group 1 - Channel1Y-Axis: Group 2 - Channel 1
Z-Matrix: Group 3: Channel 1 to Channel 16
Regards
Marco
(3,737 Views)
Hi Marco,
I don´t exactly get what you intend to achieve. Could you please explain a little bit more precisely what
the result should look like?
best regards
Marco Brauner NIG
(3,720 Views)
If this is not a LabVIEW question, I would recommend the Diadem forum for more specific help. Good luck!
(3,713 Views)
I’d like to automatically print 3D graphs in a report.
I’m working with a Matrix structure (3D Axis definition-->Curve List-->Channels).
The number of channels to select in the z-matrix is variable (depending from the signal).
Then I’d like that the z-matrix contains all the channels that are in a certain group.
Is it possible to define the z-matrix as
z-matrix: Group Name
instead of
z-matrix: Channel Name to Channel Name  ?
Hope it’s clear now
Marco
Message Edited by MarcoM on 11-29-2008 03:34 PM
Message Edited by MarcoM on 11-29-2008 03:35 PM
(3,686 Views)
Hi, I don´t think this is possible without a script which selects the right Z-Channels, but you have to make sure
that the 3d-graph gets the right amount of Z-Channels then. But you can also just create a channel-group containing
X,Y and apropriate count of Z-Channels (exactly in this order) and drag the whole group to your 3D-graph. DIAdem then
takes the right channels automatically.
Hope this helps
regards
Marco
(3,658 Views)
