problem in EXE
Hai. I'm Acquiring data using MODBUS.When I'm runing the Source code the data updates Immediately.But when I run the EXE the Data Updates very slowly typically after 10 seconds.What might be the reason?
(2,556 Views)
Hi Swathi,
I hope you are doing fine. The issue you described is not a known issue. Therefore, I would like to know how you are setting up your device , how you are transferring the data (e-g over network). And if possible can you send a piece of code that shows the problem you described ?
Fawad Nisar
National Instruments UK & Ireland
(2,547 Views)
