DAQmx Read errors
I'm refactoring an old project that uses this .vi:
DAQmx Read (Digital Bool 1Line 1Point).vi
Sometimes (not every times) this .vi fails to compile for a problem with a missing library/driver ..
Maybe this depends on this configuration:
I tried to fix it setting the library file path to C:\Windows\SysWOW64\nilvaiu.dll and C:\Windows\System32\nilvaiu.dll
but nothing changed.
Message 1 of 12
(3,658 Views)
Hi Michele,
This is a VI belonging to the DAQmx driver and is provided by NI.
You should not start to mess with VIs provided by NI…
I never had problems to build executables with DAQmx so the problem is maybe related to how you installed your LabVIEW IDE!?
Message 2 of 12
(3,627 Views)
There's a way to 'fix' the installation ?
I mean from the NI Packet Manager which Product I need to REPAIR to fix them?
Message 3 of 12
(3,624 Views)
Accepted by michele.santucci
Try repairing NI-DAQmx:
or repair just NI-DAQmx Support for LabVIEW:
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 4 of 12
(3,570 Views)
What happens if you force compile (Ctrl + Run) the VI when the fail to compile problem occurs? Does the problem recur after clearing LabVIEW's compiled object cache?
Doug
Message 5 of 12
(3,567 Views)
Need to try this. Thnx
Message 6 of 12
(3,531 Views)
Nothin'
Well... I learned how to do this just after I fixed the error by replacing DAQmx VIs ... next time I'll try this.
Message 7 of 12
(3,509 Views)
I reinstalled all DAQmx support and replaced one of the original code VI with an older version.
This fixed everything.
Anyway the only thing I changed into this VI was a diagram cleanup...
Message 8 of 12
(3,508 Views)
I fighting again with DAQmx ... I have a couple of old VIs that will not compile because of these errors:
Both VIs uses a Channel Node in this way:
But as you can see the Channel Node is not correctly referenced/populated .. and I can't understand where's the problem.
And moreover I finally noticed that this section of components pallette is not populated with DAQmx items:
I tried to repair NI DAQMx support but nothing changes.
There's a way to force LabView to update the component pallette ?
I'm missing packages?
And also examples are missing:
BTW I'm using LabView 2013 SP1.
Message 9 of 12
(3,469 Views)
Hi Michele,
And why did you install DAQmx2024Q3.1 when you still use LabVIEW2013SP1?
This combination will NEVER work!
Please install DAQmx13 to DAQmx16 for your LV2013 installation: this is the suported range!
Message 10 of 12
(3,446 Views)
