This widget could not be displayed.
DAQmx Event Question
There is a DAQmx - EveryNSamplesAcqIntoBuffer event. I have a question about it. I have a task that operates on mutiple channel. For example 5
The help says:
  • Every N Samples Acquired Into Buffer — Occurs when the user-defined number of samples is written from the device to the PC buffer. This works only with devices that support buffered tasks.
So, If I use this sw event with my task (with 5 challels), what should be the sample interval? - if I want to collect data periodically as follows: I need an event fired when every chanel has acquired 100 samples, - continuously
If I wire 100 for sample interval, this event is fired when 100 sample transfered from device to PC buffer - but I am affraid this is diffierent whan I really need.
Could anyone help me to understand DAQmx event - Channels - and Task ( with multiple channels ) connection?
Or suggest me a solution for my problem?
Thanks in advance.
+++ In God we believe, in Trance we Trust +++
[Hungary]
(2,798 Views)
Well, depending on your goal you can do it in two ways.
One is to use this Register DAQmx Events.
You can find more information on this forum: http://forums.ni.com/t5/Digital-I-O/PCI-6534-every-N-samples-acquisition-into-buffer-time/td-p/11588...
The other way is to monitor software and send the software trigger. There is a VI for software triggering.
Kind regards,
Ion R.
(2,747 Views)
Accepted by D60
Durnek,
In DAQmx, a sample refers to data on all channels for a given sample clock.  If you have 5 channels in your task, then each sample includes data from all 5 channels.  In this case, setting the sample interval to 100 will give you 100 reading from all 5 of your channels.
Hope that helps,
Dan
(2,743 Views)
Thank you very much!
[Hungary]
(2,736 Views)
