DAQ devices don't show up in LabView Measurement IO
My DAQ devices are visible in NI-MAX 5.5.1 and operate correctly.  They also work in LabView Signal Express 2012.  However, when I installed LabView 2013 and tried to use them, they don't show up in the Measurement IO so I can't acquire any data.  I have a Windows 7 64-bit computer with NI-DAQmx 9.7.5 and NI-VISA 5.4 installed.
Why do the DAQ devices work in NI-MAX and LabView Signal Express but not in LabView?
Message 1 of 8
(3,492 Views)
Did you reinstall DAQmx after you installed 2013? It is necessary to install drivers after LabVIEW.
Message 2 of 8
(3,477 Views)
I did a repair but didn't actually re-install.  I'll download the latest NI-DAQmx 9.8 and install that to see what happens.
Message 3 of 8
(3,468 Views)
Actually I downloaded and reinstalled NI-DAQmx 9.7.5 and LabView is working now.  Thanks.
Message 4 of 8
(3,458 Views)
I got a problem in NYP that this computer can't get any DAQ assistant how to acquire signals or generate signals. Can help?
Message 5 of 8
(3,330 Views)
Hi aloislowintown,
I think it would be best to post your question to a new thread, since this thread is more than a year old.  Also, please specify what NYP is.  Thanks!
Message 6 of 8
(3,292 Views)
Nanyang Polytechnic
Can you help me to connect the temperature and humidity control?
Message 7 of 8
(3,253 Views)
Hi aloislowintown,
You can find examples on how to acquire data from a DAQ device in Labview by going to the 'Help' tab, and choosing the Find Examples option, in there you should go to "Hardware Input and Output->DAQmx", there you'll find multiple examples on how to this.
Also as jMunny previously pointed out, it would be better to create a new thread since this one is pretty old, and the original issue is already resolved.
Message 8 of 8
(3,235 Views)
