Sound and Vibration - Order Cuts
Hi all,
I've started using the S&V Toolkit to perform order analysis on some data to perform correlation to a CAE model. I am using the Order Analysis VI's to plot spectral diagrams of my data which so far look good.
One of the items that I would like correlate with the CAE software is the frequency content for each order. The CAE software outputs 'Order Cuts' - I have attached an image showing the output of the CAE software that we use and what I would like to extract from the Labview results. What is the best or suggested method to be able to extract this from the spectral diagram?
Thanks in advance!
Message 1 of 1
(2,712 Views)
