DAQ assistant missing
Hi guys,
I have LabVIEW 2015 and DAQmx 14.0.
Still, the daq assistant is missing from the express --> Input palette.
Any help?
(15,998 Views)
Hi Shlok,
did you read this yesterdays thread?
(15,989 Views)
Yes GerdW,
I have DAQmx installed. But why can't I still see the DAQ assistant?
(15,983 Views)
Hi Shlok,
I mentioned the other thread because there where more questions to check your installation!
What's the order of installation? Did you install (the older version of) DAQmx AFTER (the more recent version of) LabVIEW?
(15,974 Views)
I recently installed DAQmx not more than a week ago, while I installed LV 2015 more than two months ago.
(15,965 Views)
I am installing DAQmx 15.1 at the moment now though 😉
(15,958 Views)
Accepted by Shlok1229
Message 5 of that thread will give you the answer.  Specifically
DAQmx and LabVIEW Version Compatibility
Installing the correct DAQmx version will solve your problem.
(15,933 Views)
