Same child name for different parent in tree control
I don't understand, why LabVIEW won't allow same tag names even though entered under different parent tagsSmiley Frustrated
Can I overcome this problem without changing the child tags ?
LabVIEW - 2012 SP1
Runjhun
(3,889 Views)
Because the tag is the unique identifier of the element. What's the problem with having unique tags?
___________________
Try to take over the world!
(3,869 Views)
I can have unique tags for parent. But not necessarily for a child of different parent.
Let s consider a scenario, where am executing a series of tests and within that subtests.
So am populating these tests with the list of available subtests. Now for 2 diff tests, I can have same subtest might be with different test parameters. But overall the test remains the same and hence the name.
So I need the flexibility to have same subtest name under different tests !!
(3,854 Views)
ItemTag has to be unique
ItemName can be the same
You can name your children like this:
Set ItemName = ChildrenName
Set ItemTag = ParentName:ChildrenName
As you said, your parent names are unique, so you can use that name to set unique itemtags for your children.
(3,837 Views)
