DAQ Assistant is missing in LABVIEW
Hey,
I am trying to learn about data acquisition and I don't find the DAQ assistant block why is that?
I attached two pictures.
Thanks.
Message 1 of 8
(5,804 Views)
Hi Matanlaza,
you installed "DAQmx Base", which includes only some basic BASE routines.
When you want to use higher level functions you need to install DAQmx (without "Base" in the name)…
Btw. don't use the DAQAssistent for more than just simple "quick&dirty test VIs"!
Message 2 of 8
(5,803 Views)
thanks for your respond,
but I still don't see it on LabVIEW.
In any case, I will search to download the software you saidץ
Message 3 of 8
(5,780 Views)
Accepted by topic author Matanlaza
Hi Matanlaza,
you didn't mention which DAQmx version you will need, so I just searched for "daqmx download" to find this link
Message 4 of 8
(5,773 Views)
Thank you!
I did not mention which version because I do not know what I need. I want to acquire data from my spectrum and I will try with this option
Message 5 of 8
(5,746 Views)
Hi Matanlaza,
You still don't mention which kind of spectrum analyzer you want to use - as has been requested several times before in your other thread…
(In case you are using a 3rd party device you will not gain anything from installing DAQmx - but who knows as you refuse to provide more information.)
Message 6 of 8
(5,744 Views)
Sorry, you're right I did not mention the model.
The spectrum model is KEYSIGHT N9010A.
I'm trying to learn how to acquire data from the spectrum.
Message 7 of 8
(5,741 Views)
Hi Matanlaz,
so let's keep the discussion in one place - continue here
Message 8 of 8
(5,734 Views)
