Floating numerical display of 1D waveform Y data
Is there a simple way to take the Y data from each 1D array of Waveform data and display it to a floating numeric display on the front panel
Message 1 of 10
(3,878 Views)
yes there is
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 10
(3,876 Views)
Yes, you can use the 'Get Waveform Components' function to extract the Y data. This will give you an array of doubles. You can then use an Index Array function to look at individual points and view them on your front panel.
Message 3 of 10
(3,873 Views)
I want each display to be floating while the vi is running.
Message 4 of 10
(3,869 Views)
Do you mean you want the graph to be floating?  Like "independent of any containing window" kind of floating?
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(3,867 Views)
No, just have a numeric display for each Y data in the Waveform array. Then those numeric displays would be user movable. This would be independent of the graph.
Message 6 of 10
(3,863 Views)
there is no simple way to let the user move controls/indicators at runtime.
you could do that programmatically, but it is more involved.
Message 7 of 10
(3,858 Views)
Hi bassinbc,
This has been shown above in the snippets.
This is a completely different problem: let the user move an indicator on the frontpanel!
You can use the event structure to track mouse moves, mouse clicks, and context menu actions of your user. Use all that information to change the position of the indicator on the panel/pane (using its properties)…
Message 8 of 10
(3,854 Views)
I know how to get the Y-Data. The second problem as you called it has been a problem. I found this UI Panel example sometime back and I will dig into how to use this. Just more complicated than I wanted.
Message 9 of 10
(3,839 Views)
@GerdW wrote:
Hi bassinbc,
To be fair, I think that is what the OP meant by "floating" in the subject line.
Bill
CLD
(Mid-Level minion.)
Message 10 of 10
(3,809 Views)
