DAQ Assistant VI, Samples rate and buffer
Hello everyone,
Just a quick question to get a better understanding on how Sample to read and sample rates works in the DAQ Assistant VI.
I have no particular file to commit with this post, it's more of a general question.
Using Continuous samples mode in the DAQ Assistant means that every single "sample" that the system can acquire, will be acquired. I didn't perfectly understand the possibility to set a value for the "sample to read" input. I've read that it allows to define the buffer size we want but i didn't understand why it was not at a default max value as we are using continuous sample mode.
But, using and setting sample rate to a certain value can become a limit for our Continuous sample acquisition. So i'd like to understand if there's a way to avoid getting limited by "Samples to read" value and simply being acquiring continuous data at a defined rate ? (having an illimited buffer until maximum is reached out (define by RAM volume ?)
Thanks in advance
(1,169 Views)
Accepted by topic author RedCrows
Specifying Number of Samples When Continuously Acquiring with NI-DAQmx for LabVIEW should provide the answer you need.
https://tmesystems.net/
(1,154 Views)
Indeed, thank you,
it answered most of my questions !
(1,119 Views)
